ORIGINAL: COM
Hi Brett, Yea I only post some of the table just to show the 0s in the table.
Rob, Can you confirm if there is a problem with the latest curve generator?
There isn't.
In the old curvegenerator you have to fill in all 255 values, every input has his own value.
In the new curvegenerator you only have to file in 20 values, only the value you fill in has his own value the other values will be calculate.
Feeld 1 is value 2, feeld 2 is value 8, between feeld 1 and feeld 2 there are ~20 calculate values.
If you want to fill in the new curvegenerator also 256 values I can change the sheet, but I can't see wat you win with it.
