RE: Sebart Wind 110
Robart hinges are offcourse fine too, but there's really nothing wrong with CA hinges. If you break them, you're probably doing something wrong mounting them.
The trick to CA hinges is that you HAVE to use THIN CA and you HAVE to glue them in at once. Don't do one side first and then the other.
Easiest way to place them correctly is to put a pin through them in the middle and then insert them into one half. After having inserted them all, put on the second half. The pins are there to keep them in the middle. Remove the pins and put a drop or 2 of thin CA on both sides, and you're done.
