RCU Forums - View Single Post - New CDI - opensource project JMJ and Bigboat
Old 02-09-2010 | 03:47 AM
  #732
Bigboat
Default RE: New CDI - opensource project JMJ and Bigboat
ORIGINAL: gr8flyer55
Brett.. I used the timer board set for the 7000 rpm test..I don't have anything else that spins fast enough to try higher speeds.
Can't you use your pcb-drill ?
Board # 4 seems to be a failure.. Just built it and there is something wrong with it.. Bad parts placement or something..not sure yet.. did have to move a few components and omit the diode cause my timer board already has it on. Tried tracing the circuit with a logic pen and signals and voltages are wrong.. Oh well... Back to drawing board for #4.
I check the board twice, but I can't find any failure.
