RCU Forums - View Single Post - Connecting Rod
Old 02-09-2010 | 09:42 AM
jmaxey51
Default RE: Connecting Rod
ORIGINAL: xxxtsuperstud18
ORIGINAL: jmaxey51
when taking the back plate off make sure the piston is up (closest to the glow plug) or when you pull the back plate off it will break the piston. i have seen people do it time and time again.
why would it break the piston??? (this isnt me callin u a liar, this is me wantin to know for future reference)
because the back plate has a groove cut out to let the piston go into. and if its down the piston is in that notch/groove and when you pull it off it will break, nitro engine pistons are so small/thin they will break easily.
<br type="_moz" />
