ORIGINAL: Ian78
Only thing I don't like so far is that the bolt doesn't tighten the 12mm conversion nut very tight.
hi ian
can you post a photo of the hubs
i would say yes it does make a difference even though its not much bigger
i can still spin the car round on dry roads with grippy tyers and its worse when its wet
and if you get a better motor you will notice the differance
