RCU Forums - View Single Post - Subaru Impreza WRC 1/10 Bycmo
Old 02-09-2010 | 04:48 PM
  #621
dust75's Avatar
dust75
Default RE: Subaru Impreza WRC 1/10 Bycmo
hi ian
do you have the upgrade axels ?
if not either put the hub on the axel then use a flat blade screw driver in the back to tighten the wheel nut
or if you have any stapels cut/ bend to size and use that as a pin
hope that helps
