Bobcat Durostruts
Guys, I also upgraded my Bobcat to Durostruts. The other thing you have to do (besides notch the drag brakes) is to not remove the lower wing landing gear cutouts. The laser cutouts are positioned for the wire gear, and don't fit the new strut position. The openings have to be moved slightly to accommodate the Durostruts. It is a simple mod, but you can save some work by gluing the cut outs in place before you remove them, and then make new openings to accommodate the new struts. BTW, the Duro struts are super and very high quality - I'm really glad I decided to make the upgrade. Hopefully, BV will offer this as a standard option from the factory in the future.
Regards, Les Morrow
