ORIGINAL: magnat
1. What was the difference between Reef Racer 1 and 2 ??
2. Do they use the same 7.2 Volt 6 Cell as the cars do ??
3. How good are they at handling wake ?
4. If 3 are running at the same time and have a collision, How will they survive ?
5. What sort of motor do they run ?
6. If they dont use the same packs as the cars, Can you possibley fit the Stick pack in ?
If anyone owns one, what trouble have you encountered ?
I'm thinking about buying one and did some studying:
1. Reef #1 had a hinged top that leaked badly. The battery was long like a car battery. The water intake was between the prop and rudder.
2. Reef #2 has 2 round sealed 'lids' for access and helps stop leakage. It has a short fat battery because they moved the motor and there is limited room now. The water inlet moved behind one side of the rudder.
3. These boats handle most anything. Wake jumping looks FUN! Brushless conversions can submarine as well!
4. ??
5. I believe it is a 380 brushed motor with coiled tubing cooling
6. Anything is possible!
