RE: Convert from Blade CP Pro to CP Pro 2
Thanks RotaryDoc for the fast reply. Yes the radio comes with the receiver and for $59 + shipping its a great price for a starter system. Here are the radio specs.
Features:
LED display, Show model type and battery voltage on normal status.
5 models parameters store supported
Support HELI(helicopter) mode and AERO mode. Following mode is supported in each mode.
Heli mode:
HP1 : Normal helicopter with 1 servo
HP2: Swash helicopter with 2 servos
HP3: CCPM 120 swash helicopter with 3 servos
AERO mode:
AP: Normal aero plane
VP : V-tail plane
DP: Del ta wing plane
7 channels standard servo signal output
Support 5 points throttle(THR) curve on NORMAL mode and IDLE mode.
Support 5 points pitch(PIT) curve on NORMAL mode, IDLE mode and HOLD mode.
Set reverse (REV), sub trim (SUB) and travel by LED and button.
Dual rate (DR) control supported
Throttlehold supported
Gyro sensitivity adjust supported
Return to battery voltage display after no operation till 30 seconds.
Beep when battery voltage low than 8.6V (Once per second).
Included;
1 x 2.4Ghz transmitter
1 x 2.4Ghz Receiver
1 x Bind Plug
1x Manual
