One additional thing. . .do you have a picture of the engine, installed on your plane? Always helps to be able to see the installation. I once fixed a guys "horrible running" engine by merely turning the cover plate for the pressure regulator 90 degrees, so that the vent hole was not facing directly into the prop wash, but was under the lip of the cowl, in calm air. Engine ran great after that.
