RE: accucel 6 charger question
TPH1,
Do you have an Accucel 6 and trying to hook up a LIPO battery? If so, you have to connect the charge pigtail, from the batt., to the banana jacks on the side of the charger. The charge pigtail is the one with the larger wires. You may have to make or buy an adapter to go from the banana jacks to what ever type of plug you have on your batts. charge pigtail. The other pigtail, from the batt., with the small wires, should have a small white plug which is for plugging into the balancing ports next to the banana jacks. Depending on the number of cells your batt. has will determine which charge port to plug into. Here is a photo of what it looks like.
