RCU Forums - View Single Post - EQ6 - adjusting multiple servos on channel 1 (ailerons)
Old 02-11-2010 | 09:24 AM
rrritchey
Default RE: EQ6 - adjusting multiple servos on channel 1 (ailerons)
ORIGINAL: NiknJen
When I try to adjust the servos (for centering) on channel 1 (ailerons) on the EQ-6 the servos don't change. I have an Futaba 14 channel FASST receiver. I have the Smartfly pigtails as follows: 1 on smartfly to 1 on receiver, 2 on smartfly to 2 or receiver, 3 on Smartfly to 3 on receiver, etc. I plan on using flaperon and have the ailerons plugged into channels 1 and 6. I have 4 aileron servos (2 for each wing) Am I correct in plugging the 2 left aileron servos into channel 1 on the Smartfly and the 2 right ones into channel 6? I notice channel 1 does not have an A or B marking or an LED?
Hi. Channels 1 and 8 are not adjustable. For Futaba receivers the way most people hook them up is as follows:
Rx Ch 1 -> Eq6 Ch 2 (Aileron)
Rx Ch 2 -> Eq6 Ch 3 (Elevator
Rx Ch 3 -> Eq6 Ch 1 (Throttle)
Rx Ch 4 -> Eq6 Ch 4 (Rudder)
Rx Ch 5 -> Eq6 Ch 5 (Gear)
Rx Ch 6 -> Eq6 Ch 6 (Aux 1)
Rx Ch 7 -> Eq6 Ch 7 (Aux 2)
Rx Ch 8 -> Eq6 Ch 8 (Aux 3)
Let me know if you have any other questions.
