RCU Forums - View Single Post - Difficulty starting Black Widow
Old 07-12-2003 | 02:29 AM
Lynn S
Default Difficulty starting Black Widow
remove the glow head and see if you have a bright orange glow when you connect your battery. If not ,the battery is weak, or the glow plug is bad. If you have a good glow plug working and fuel it should start. Open the needle about 2 1/2 turns. and just a little bit of fuel to prime.
