RCU Forums - View Single Post - drift tire question
Old 02-11-2010 | 10:21 PM
cat samich
Default RE: drift tire question
ORIGINAL: SIRCC
those homemade PVC tires are just about the cheapest way to get into the drift scene, they are for slow paced drifters or begginners, the flux system you will need alot of practice or some A-drift tires from HPI which run about $20 a set of 4. the flux system is about a 9turn motor to much speed for a begginner and PVC tires. If you going to use PVC tires 17t, 19t or even the silver can motor will drift with those tires without a problem. here's a link to my drifter using the mamba max 5700. follow the red car
[link]http://sirccc.com[/link]
well the flux hasnt come yet, im cutting my teeth so to speak with this 4-tec i picked up. it has a 19 turn motor in it at the moment.
i was more interested in what material to buy and how to make these tires so that i can get started learning how to drift
