RE: Time to stop using CA/CA+ - breathing problems
I was having the same problem. I work in my garage and the fumes were killing me. Now i have to work with the garage door open so I can vent the place while i am working. It sucks with the cold weather too, I would rather have the door closed. Titebond sets up faster than elmers but not nearly as fast as CA. I found that I use the titebond when i am sheeting something, maybe I should use it and just tack with thin CA to keep the pieces together while the titebond cures.
P.S. you can buy the titebond at home depot. It is alot cheaper than CA.
