ORIGINAL: mydartswinger
And then there were 4. Based on all of your comments, I've eliminated a few from my choices. I did so because I'm a bit hard on the throttle and brake, want a stable and good handling car (possibly even forgiving), and need something that'll be durable. Also, I don't want a car that'll be too much of a pain to keep in the running (I got tired of DNFs racing touring cars). I am aware that some of all that will be part of what type of setup I put on the car, but it does help to have a good platform to start with.
The buggies I've narrowed it down to are:
-Associated RC8B Factory Team
-Mugen MBX6 (Both)
-O'Donnell Z01B-SG
What are the differences between the standard MBX6 and the M-Spec? As far as I can tell, they are the same buggy. However, the M-Spec is a roller, while the standard is a kit. If that's the only difference, I'd prefer the kit.
K_B,
I checked out that Associated servo, and WOW!!! I've never seen a servo with those kinds of specs under $100. I would even put that servo in my .50 size helicopter. Thanks for the tip on that. BTW, next time you're at Chilcoot Charlie's, have a drink for me. I bet ya'll got plenty of weather for that right about now. Then again, you're not in Fairbanks. LOL. Good times, good memories!!!
the difference between the 2 mugens are that the M-Spec is fuly built with the best setup that the pros run. built to exact specs on everything, its worth the extra money IMO but if you like to build the kit then go with the standard kit. but you have the three best kits IMO picked out. ill be switching to one of those three when i get some extra money. also on the servos i have had great luck with the Hitec 7955. i have been running the same one for over a year now on both, switch it back and forth from truggy and buggy.
<br type="_moz" />
