RCU Forums - View Single Post - Engine Cuts Out: engine or speed controller problem?
Old 07-12-2003 | 07:01 PM
rctimm99
My Feedback: (34)
Default Engine Cuts Out: engine or speed controller problem?
Dan,
I had the same problem with an astroflight 020... disconnect all your servos and if the problem goes away (which I bet it does) you need AstroFlight to fix it.
These smaller faster servos of today like the HS81 can spike at high amps which can shut down a BCE ...
If the problem goes away with the servos dissconnected, call www.astroflight.com ... Bob is a good guy.
Tim
