RCU Forums - View Single Post - Carb Insert ?
Old 02-12-2010 | 09:10 PM
crazykat
Default RE: Carb Insert ?
Hhmmmm.... sorry to hear that. Did you try richening the low speed needle? When mine revs high after a high speed run, i richen the low speed and it does the trick. I have never had a high speed bog with this engine. temps are usually between 210-230 after a speed run. and i am using an OS A5 plug.
