RE: Great planes ultimate 160
Hello Tom: I did not explain clear enough,I mean that I will still solder the extension to the carb plate hole,and run a line back into the fusilage,just wondered if it would make a difference if after I solder the tube extension,can I reinstall the plate so that the soldered on tube is opposite to the original location,ie,rotate the plate 180 degrees.
