RE: New CDI - opensource project JMJ and Bigboat
Don't use pullup or down resistors, they are set enable into the pic.
Do you set the fuses like the HOWTO from Charlie ?
I think the copy past is the problem.
Copy the code into a real txt-file, no notepad or something like this.
Open a DOS-sesion, typ *edit code.txt* without the *'s, past the code into this file, edit the code and safe this file somewhere.
Now you have a real file with the code ono to one.
