RCU Forums - View Single Post - New CDI - opensource project JMJ and Bigboat
Old 02-14-2010 | 09:09 AM
  #778
Rallyfinnen
Default RE: New CDI - opensource project JMJ and Bigboat
I guess that fuses is the same as config bits?
I have two sets of instructions (one old and one new?) and Master Clear Enable is ON in one, and OFF in the other. I tried both settings, which is the correct one?
The other settings seem to be the same.
Now I have also checked the strobe output (not using that one either, so it's not connected), and that one seems to be dead too.
I have two PIC's, so I have tried both of them just in case.
5V is present on pins 5 / 14, and I have pulse on pin 7, that should be enough to get the output on pin 6, right?
If I use the test function in the code, does it enter test mode any time, or only at start up?
It should not be a copy/paste problem, since the downloaded hex is not working either.
I will remove the pull down resistor again, just from looking at the data sheet it seemed like it was a pull-up output, so I thought thet it was needed.
