RCU Forums - View Single Post - New CDI - opensource project JMJ and Bigboat
Old 02-14-2010 | 11:21 AM
  #781
Bigboat
Default RE: New CDI - opensource project JMJ and Bigboat
Wat do you have todo.
Start the exel curve generator and draw your curve.
Copy past the code into MicroC and now you can edit the code.
(DON'T SHUTDOWN EXEL BEFOR YOU HAVE PAST THE CODE)
Edit only the line; Delay_us(1650); // Calculated delay
Don't forget to set the fuses into the configfile as scribe into the HOWTO.
