RE: New CDI - opensource project JMJ and Bigboat
Rob...
I finally figured out the trigger problem with cdipwr-4 board.. The hall resistor was in the wrong place..has to be before the cap on the trigger pulse input trace to reference the signal to ground. Made the changes to the printout I did and added what I changed to get it to work. Also figured out the diodes D-2, D-3, D-4, D-5 and placed the corrections on this sheet.
Thanks again for your constant support with my problems, sorry for the frustration I caused with my board not working...
It now functions great! In fact I built 4 more of them.. Confidence is high right now on a completed project!
Rallyfinnen has the right idea, you are the one I look to for support!
John
