RCU Forums - View Single Post - Spot On 50 Build log.
Old 02-15-2010 | 08:47 AM
  #75
TomTreese
Default RE: Spot On 50 Build log.
If you're mounting your engine inverted the carb will be lower then mounting it horizontal...I have my OS 55 with a pitts mounted at 90* and the center of the tank is in line. I also filled the top inside of nose with light foam padding to cushin the tank. This also creates a tight fit and holds it in place.
I had two Venuse 40's from Great Planes. I originally installed an OS 46 FXI inverted and it was a nightmare. Tough to start unless you turned the plane upside down, even with an idle-bar glow plug and it went deadstick about 70% of the time when you throttled back to land. After I turned the 46 to 90* with a pitts it was perfect.
