RCU Forums - View Single Post - DLE30!
Thread: DLE30!
Old 02-15-2010 | 09:27 AM
  #2027
craigteffe's Avatar
craigteffe
My Feedback: (24)
Default RE: NEW DLE30!
ORIGINAL: captinjohn
ORIGINAL: fitson
I was going to post what happened to me. I was re-installing the RCXEL ignition and no spark. I checked the connectors and noticed one of the pins had moved out of place. Got that fixed....but these connectors seem kinda cheap made. I think I will replace with them with much better deans...any input on that? Thanks Capt,n
If you are going to change the plugs why not solder the wires together? If you want to put plugs on later not much more work.
For what we pay for this RC stuff they should come with a high grade connecter in the first place. If I solder the wires together & get a short it would be hard to undue quick. Or for testing. Just don,t know....
For what we pay for tne Engines I would think they would idle out of the box below 2100 RPM without dying. Lets sand the SPS on the piston, make a different backplate, an intake stuffer, have to mount it at a angle, and what ever else is going on then complain about the connectors????
Maybe DL could do a little work on these engines, and then have a Great Little Engine.
