RE: Sterner - DH 100 VAMPIRE buildingThread
I´m slowly making progress on the left wing panel. I have glued the wing skin onto the ribs and spars on the top. In two steps... first the inside skin up to where you take the wing apart, and then the outer skin. Using white glue..except when starting, using cyano to secure the front edge of the skin to the leading edge spar.
Turned the wing upside down and glued all the spruce spars in place...using whatever was heavy to press the spars down into the notches...
