RE: NEW DLE30!
Most single bolt hub conversions have a short extension that fits into the hole in the end of the hub..I helps to center the adapter..Doesn't take much...
Drilling the holes in the hub to use larger bolts is no big thing..5mm .8 flatheads are stronger than the little ones the enigne comes with...Takes about 5 minutes..#21 drill and a 5mm tap...
