RCU Forums - View Single Post - Best riveting tool?
Old 02-15-2010 | 12:15 PM
dasintex's Avatar
dasintex
My Feedback: (10)
Default RE: Best riveting tool?
To burn the Slot of Screws as well as the Srews at the same time, insert or jam a small width strip of brass or copper sheet (shim material)into the end of tube; the strip or sliver should be the width of the inside diameter of the tubing you are using, the effect would be the creation of a circle with a slot across it immitating a screw head when etched or burned into the paint/primer.
