RCU Forums - View Single Post - Proper Temperature for Engine??
Old 07-12-2003 | 01:40 PM
BUGGIES_R_US's Avatar
BUGGIES_R_US
Default Proper Temperature for Engine??
You have other problems as well! What your telling is is only half the story!
How about when you first start it? How does the engine run then? If it has no top end and stalls, it sounds like its lean.
I suspect that the needle may be bad or you have an air leak in the carb?
ram
