RE: RC8T Diff Problem HELP
I literally took it apart the way it was, refilled the oil and put it back together and it just didnt go back together the way it was supposed to. The only shims I removed were the ones under the large bevel gears. Under those gears are 2 shims. I only removed one and it seemed to have worked but now I have the weird rotation problem with the wheels. when spun in one direction they spin correctly (opposite directions) and when spun in another direction they move together in the same direction. Im wondering If I should add a smaller shim to the shim under the bevel gears but one that is slightly thinner.
