RCU Forums - View Single Post - Control Horns
Old 02-16-2010 | 11:07 AM
KW_Counter
Default RE: Control Horns
Pete,
I have never done this - just using logic.
I assume the wood is balsa.
If so, you would need to satuarate it with CA to give it some strength.
I would still be nervous.
How about cutting a recess on the bottom, harden the wood, glue in the back part and then covering?
Good Luck,
KW_Counter
