RE: Control Horns
As long as there is a hardwood or plywood mounting point for the horns, wood screws will work just fine. Just be sure to harden the holes with thin CA. I also like to add a little dab of thick CA on the threads when I put the screw in. Not sure if that is necessary but it makes me feel better. I've beat the crap out of airplanes with control horns mounted like this and no failures so far.
