ORIGINAL: jamiebravo
Phew! Glad that is over! I hate taking a grinder to shiney cowl. This is what I ened up with. I had to cut alot more so I could manipulate the cowl to get the pipe threaded on. I finally got smart and put some tape over the painted head but not after I managed to scrape some off. I used a whiz wheel to cut a hole and then I shaped it with a grinding stone, I used one for sharpening chainsaw blades, it is small in diameter.
Yeah 10lb. into a 5lb. paper bag, I was expecting to hear a crack any minute! At one point I had to unbolt the engine through the cowl (Luckily I had one nut on) and remove the engine to get the cowl off. Tight fit!
aesthetically, it might not be the prettiest, but that engine will benefit with more airflow over the heads for keeping it cool.
btw...it looks great to me
