I don't know this system and have never see it
If you connect only the ground to the timer/powerboard and place the other wire direct on the IGBT it can be a problem.
Don't connect any other parts to the engine, this will blow your electronics, the coil produce a high Voltage, >15,000 Volt.
I 'll draw how I think you have to connect the boards.
