RCU Forums - View Single Post - HOME MADE HINGES PART 2
Old 02-16-2010 | 06:16 PM
box car
Default RE: HOME MADE HINGES PART 2
So far friction has been working, 1/16 hole with 1/16 music wire is a honeymoon fit. What I am going to do is put a little heat shrink on each side oftwo heads, a little heat and your set but if you need to take the shaft out just cut off the heat shrink. When I put a shaft in I use my drill with a point on the end of the shaft.
Ken
