ORIGINAL: Riverview
Hi Mikael, You can get all of the specs for the Saito 100 Twin Here:
http://www.horizonhobby.com/ProdInfo...oke_Manual.pdf
I purchased the 100t a couple of months ago to install in a TF 182. I have the engine mounted and it fits pretty nice. I am using thefiberglass cowl from fiberglass specialties:
http://www.fiberglassspecialtiesinc.com/newprod.htm I had to dimple the cowl slightly for the top rockers and you need to cut hole for the two needle valves. I will post a couple of pictures late rtoday of the installation.
<hr /> To post a picture, use the "POST REPLY" button at the left bottom of the last post. Do not use the "Fast Reply" button
When the edit screen comes up, just along the bottom edge of the edit part is a line that has "Upload Files" button
Use this method to upload a file from your computer hard drive only
