RE: New Lipo battery problem
More importantly, how are you determining that you're only getting 100mAh?
There are quite a few reasons why you'll see what you're seeing...
If you are flying to LVC, and then the charger is only putting in 100mAh, your battery is too small for the load being placed on it.
The battery is not really discharging. Its voltage is dropping due to the excessive load being placed on it by the motor/prop combination.
