RE: HOME MADE HINGES PART 2
Why not use the hinge point concept.. take a longer nylong bolt cut in half. With a dremel or similar make slices in the ends, place the "fingers" together, drill your hole, slide the full length wire in wire in and your done. To keep the wire in place you could place a single bolt a the bottom with a hole not drilled all the way through to hold it in place.
