ORIGINAL: Campgems
I'll add one more thing also. I really like Minnflier's recomendation. I would tack glue a strip flull length of the surface about 1/2'' behind the Leading edge prior to makeing the cuts. That will keep from squeezing or spreading the LE when the replacements are put in place. You could also do a serious pin job on a building board, leaving the width of the LE hanging over the edge. You don't wan't to build a twist into it with the repairs. Once the LE repairs are made, then remove the strip.
Don
EXCELLENT EXCELLENT EXCELLENT suggestion!!!! Thank you SOOOOOOOOOOOOOOOOOO much!!!!!!!!!!!!!!!!!
This plane will one day fly again!!!!!!!!!!!!!!!!!!
