RE: Need Help
How far along are you?...the fuse and wing should be fairly straight forward,,,the CG should be on or very close to the spar and there is probably 2-3 inches of dihedral......If you have a club nearby, I'm sure the designated trainer could help you with the build,,on the other hand if began building means you opened the box and closed it back then I would suggest the same a builder/partner or getting a similar kit and build them both........your gonna need help to fly it, nothing wrong with asking for help to build it...sometimes on the bay or some of the sites they will say there is no building manual,, but to click on a link to the manual, but those are usually for ARF's....hope it helps....Rog
