RE: 3s vs. 6s setup? Jollymotor upgrade..
correct!
you are on the right path, going 6s with 1/2 the kv of the stock motor you will longer runtimes and a cooler running system.
but if you run 6s on the stock motor, that would be to much rpm and cause lots of heat and damage
