RCU Forums - View Single Post - Eletronic engine syncronizer **SUPPORT **
Old 02-19-2010 | 01:37 PM
  #836
Robby
My Feedback: (18)
Default RE: Eletronic engine syncronizer **SUPPORT **
Mark,,
First off,, people are die'n to see you and you are at work playing on computer... Why?
Second,, turn on the heater in the garage... / \
Third, the answer is NO.. Both engine sensors have to have RPM and throttle stick has to be
within TS activate range..
You *could* try to remove glow plugs and use two starters to turn engines and watch
the sync LED. That would require two starters, two people to operate them and a person
on TX... Basically, a major PIA... [:@]
