Help with large scale setup.
I’m in the process of expanding my knowledge into setups for larger scale aircraft I have a scenario I’d like you to consider, get recommended setup, and answer a few questions maybe.
What would I need to setup a redundant system for a plane with the following requirements; and can your setup run off a nine channel radio(2.4Ghz) 11 digital servos (2 on each half aileron and elevator, and 2 on rudder, plus a throttle servo and a payload drop servo. So what would your initial recommendations be so I can ask more questions. Thanks.
