RCU Forums - View Single Post - CMP Zero Makeover
Old 02-19-2010 | 09:43 PM
  #260
jstanton's Avatar
jstanton
My Feedback: (14)
Default RE: CMP Zero Makeover
LDM,
That sounds like a good idea. I used 3/8" dowels so I hope I can find the plastic tubes you talked about in that size I have everything done except for the landing gear I ordered. They should be here Monday and I install them and balance the Zero. I hope with putting the 1lb weight on the plywood extension and the elevator and rudder servo's in the fuselage I will not have to add any more weight
