RCU Forums - View Single Post - Engine right thrust or rudder slaved to throttle?
Old 02-20-2010 | 10:18 AM
arvids
Default RE: Engine right thrust or rudder slaved to throttle?
Howard:
Why should it be nessesary to switch off the rudder mix when flying constant speed/cruising mode, you can't switch off the
engine right thrust when flying like this. Is it because the airstream is different? If so, why doesn't the plane track to the
right when flying constant speed/cruising mode with right trust on the engine?
Yes, I have to read the book....
Arvid
