RE: New Lipo battery problem
Thanks for your detailed and carefully thought out answer albeit a little over my head but if I understand you correctly it may be the older 11.1v battery which is probably close to 2 years old with unknown number of flight time. I will check it alone on the watt meter. I forgot to mention that it showed 20.18v in the right upper corner of the meter with the 11.1v and 7.4v connected in series and 16.31v with the (2) 7.4v batteries connected if that helps. I borrowed the meter from a friend and obviously don't know that much about batteries -spent all my life learning medicine. Thanks again I'll get back with you later with more results. I've got a 5s Turnigy battery coming on a slow boat from China which I plan to use as well. Terry
