RCU Forums - View Single Post - Hitec Eclipse w/ Spectrum Module (problems?)
Old 07-13-2003 | 01:48 AM
rcflyertim
Default Hitec Eclipse w/ Spectrum Module (problems?)
There is so much that has to be taken for granted when you say "all things where the same". Was this the first flight with the radio> Did you do a range check? Did you make sure you had dialed in your RX channel? Did you check your battery voltage? These and many other Q/ have to be checked off before we go after the TX itself was at fault.
