RCU Forums - View Single Post - Hitec Eclipse w/ Spectrum Module (problems?)
Old 07-13-2003 | 06:39 PM
gtalbot
Default The Same
By "the same" I mean the two airplanes had the same brand receiver, same channel. Both were flown a couple dozen times each. The only change was the new transimitter.
I made sure the transmitter was on the proper shift, the correct channel, etc. The TX and RX batteries were charged appropriately. I range checked before I flew...it went well also.
The plane flew flawlessly as always...I was very happy with my new tranmitter...then after about 10 minutes, all heck broke loose.
Today, I rechecked the TX with the second airplane. It also range checked well. But here's the catch...if I leave the TX and RX on, after about ten minutes, the plane starts glitching badly. If I turn off the system, then turn it right back on, it contimues to glitch. If I turn off the system for a while then it seems to work fine again for about ten minutes, then all heck breaks loose again.
It would be different if this happend with one plane and not the other, but it's happening with both. I've never even had a single hiccup aout of either of my RXs. Something isn't right with the TX...I'll contact Hitec Monday.
Gordon
