Originally posted by gtalbot
Which Airtronics receiver?
Mine all are the 92777Z seven channel receiver.
gtalbot, here's the story: I dug out the plane I thought I put an Airtronics rx in, and it turned out to be a Futaba. To make amends, I dug out another plane with a 92875Z Airtronics rx. I set up the Eclipse for this shift and freq. The controls responded fine, but for some reason, the elevator and ailerons were reversed. I left it on over ten minutes, and the module wasn't hot at all. Barely even warm. It was still working fine after 10 min. Hope this helps. Tim
