RCU Forums - View Single Post - Help for making a plug from foam
Old 02-21-2010 | 12:45 PM
jon sykes.1
Default RE: Help for making a plug from foam
Try using polyester spray filler,it like car body filler,only thinner,you will need to use a spray gun with at least a2mm fluid tip .This stuff sands really nice,3 coats will give good build,allowing plenty of sanding,watch the pot life,which is normally about 15 mins,less in warmer climates!If you dont you'll be buying a new spraygun,dont ask how i know!!!!
